11-05-2019 02:35 PM - edited 11-07-2019 10:10 AM
I carefully looked through the entire forum, tried with the printer buttons, the error does not go away. I ask for professional advice here on how to get rid of it.
I can ask professionals to share this, only for pinout of the QY6-0084 head contacts:
Pin No. Signal Name Function >>> This is the pinout for QY6-0054
1,2,3 | B_GNDH | Heater GND |
4 | B_DATA_Y2 | Serial data input aor Y2 heater |
5,6 | VSS | Logic GND |
7,8 | A_GNDH | Heater GND |
9 | B_DATA_M1 | Serial data input for M1 heater |
10 | B_DATA_M2 | Serial data input for M2 heater |
11 | B_DATA_Y1 | Serial data input for Y1 heater |
12 | CLK | Clock signal |
13 | LT | Data lath enable signal |
15 | B_HE2 | Heat enable signal |
16 | B_DIK | Head temperature cathode side |
X 17 | VHT | Head power transistor driver power supply |
18 | B_HE1 | Heat enable signal |
19,20 | VDD | Logic power supply |
21 | E_DI | Head EEPROM serial data input signal |
22 | B_RANK(NC) | Unused |
23 | B_DATA_C1 | Serial data input for C1 heater |
X 24 | B_DATA_C2 | Serial data input for C2 heater |
X 25,26 | B_VH | Heater power supply |
27 | E_SK | Head EEPROM serial data clock input signal |
28 | E_CS | Head EEPROM chip select input signal |
29 | B_DIA | Head temperature sensor anode side |
30 | E_DO | Head EEPROM serial data output signal3 |
31 | B_SH(NC) | Unused |
X 32,40 | A_VH | Heater power supply |
X 33 | A_DATA_K1 | Serial data input for BK1 heater |
34 | A_SH(NC) | Unused |
35 | A_RANK(NC) | Unused |
36 | A_DIK | Heat temperature sensor cathode signal |
37 | A_DIA | Heat temperature sensor anode signal |
X 38 | A_DATA_K2 | Serial data input for BK2 heater |
39 | A_HE | Heat enable signal |
Knowing the sites, I will seal some of them with electrical tape, lose one color, but suddenly the printer starts working.
11-08-2019 04:25 PM
Hi Vlad_Zaytsev,
The B200 is a general hardware error and the printer would require service. You can try a hard reset by unplugging the printer while it is on and then press the power button 5 times. After that let the printer sit for 60 seconds then power it back on. If the error does not clear, the printer will need service. For service you can perform a web search with the key words "printer repair" and you zip code. That will pull up any electronic repair shops in your are that can service printers.
if the printer is still in it's 1 year warranty, please contact the Canon support team at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST. You will need to have a copy of the printers receipt.
11-08-2019 04:25 PM
Hi Vlad_Zaytsev,
11-09-2019 01:09 PM
11-28-2019 03:36 AM
01-18-2021 01:33 PM
11-07-2022 03:09 PM
OK, strangely enough the "unplug and push power button 5 times" reset worked. My Pro-100 was completely dead, with alternating power and alarm lights. I don't know how in the world a general user would be expected to know this fix, but I'm happy I guess. Sheesh!
01-18-2021 01:32 PM
I tried the hard reset - turn on, unplug, press start button 5 time, plug, restart.
The B200 went away and the printer is functional
Lucky, I guess
