07-28-2014 09:27 PM
07-28-2014 09:57 PM
07-31-2014 07:09 AM
Hi Milld4,
You can use paper in the following weight ranges:
From the Rear Tray: From 17 to 28 lb (64 to 105 g /m2) (plain paper except for Canon genuine paper)
* You can use non-Canon genuine specialty paper that is up to 53 lb (200 g /m2).
Do not use heavier or lighter paper (except for Canon genuine paper), as it could jam in the printer.
From the Manual Feed Tray: From 4 to 23.6 mil (0.1 to 0.6 mm) (up to 93 lb (350 g /m2))
Do not use paper thicker or heavier than this, as it could jam in the printer.
More information on the media types, sizes, and thicknesses you can use with the printer can be found here.
Hope this helps!
07-31-2014 07:53 AM
