04-11-2026
12:28 PM
10:04 AM
Hi, first of all I am new to this forum, and am excited to join you all.
I am using a Canon Prograf-1100 printer, and was wondering if anyone has tried using it to print on nonphotographic paper, such as traditional 300-lb artists watercolor paper? I have a project in mind and would like to try this, but am worried about damaging the printer head.
Thanks!
04-11-2026 08:08 PM
No experience with that here. Google says it CAN be done, but per the manual, not so much. Per the Canon manual only upto 107lb paper is supported in the manual tray. https://ij.manual.canon/ij/webmanual/Manual/All/PRO-1100%20series/EN/BG/bg_b330.html.
Since you're outside the realm of what is supported in the manual I would expect you'd be operating outside of warranty support if you damage the head and Canon could tell you that you were using paper that was in the "Media types that you cannot use" - ...."Paper that is too thick".
The Google AI response is below, but Google doesn't support Canon printers, Canon does, so doing so seems like it would be at your own risk (and if you look hard the AI response is contradictory and quotes the manual max of 107lb paper then tells you it's still ok). I suggest you call Canon before you try it and take note of who approved your proceeding if someone says it's ok.
Google AI Response:
04-11-2026 08:08 PM
Google AI Response:
04-11-2026 08:18 PM
Thanks SignifDidgits! For my project, a 300-lb paper isn’t really necessary. I can use lighter weight paper. So you’ve actually answered the most important part of my question. It seems I may indeed use watercolor paper. So thank you!!
04-12-2026 08:32 AM
Glad it was a positive outcome! Let us know how it turns out and thanks for visiting the forum!
