imageRUNNER ADVANCE 6551i LCD Screen Not Working (No Display)
jpgatpo01
Hi everyone,
I'm currently working on a Canon imageRUNNER ADVANCE 6551i, and I'm running into an issue where the LCD panel does not display anything. The backlight turns on and off, but there’s no actual image or user interface showing on the screen. The machine powers up and all other lights on the device are functioning—except one orange LED near the back.
So far, I’ve tried the following:
  • Checked all cables and connections to the LCD panel.
  • Inspected the FM1-M963 (touchscreen controller?) and FM1-Y995 / FM1-M981 boards, but not sure which one directly controls the LCD.
  • Verified that the printer boots (green LEDs and fans running) but cannot access menus due to the blank screen.
Has anyone experienced this issue before? Could this be a failed LCD, a controller board, or possibly a firmware issue?
Any suggestions or troubleshooting steps would be greatly appreciated.
Thanks in advance!
5 REPLIES 5
jackabroy665
"Try restarting the printer and checking cable connections. If the LCD is slow not working, it might be a hardware issue. You can also check tutorials on freecine for help or service guides."
Ask ChatGPT
i already tried chatgpt. and disconnecting cables etc still same issue. do you guys know where i can download the Canon SST V4.32EV?
Moderator
Moderator
Thanks for joining the conversation, jpgatpo01!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
where can i order a control panel pcb?
I suggest you engage with a Canon Dealer for support and repair of your ImageRunner.
Canon does have a parts order desk, but a replacement PCB or LCD might not be a user replaceable part.
Canon Parts Order Desk (866) 481-2569
i suggest you follow Danny's advice and engage with Canon's Dealer Network.  🙂
