04-05-2023 02:06 PM
Hello,
Is there an easy way to override the Skew alert for all papers through the settings on the 4100 and 2100? I know you can do it individually for each paper type. Or is there an easy way I could edit settings for all the papers on my computer and then transfer it via usb? I am working with numerous 4100s and 2100s so just looking for an easy work around.
Thank you for your time
Richard
04-26-2023 12:51 PM
Hi rsa0223,
There isn't a global setting that can be pushed to disable the alert for the PRO-2100 and PRO-4100 printers.
04-26-2023 09:53 PM
Would like to recommend an easier way to get rid of the skew errors. It is virtually impossible to load fine art papers on a regular basis without turning the errors off. This occurs both with roll and sheet. Just fed up of someone accidentally changing settings back to default and clearing out the skew errors off that you manually have to enter for each paper. Very counterproductive.
