Imagerunner ADV-C5800 IP-FAX to SIP Server Setup
mike11
Searching for assistance to setup a Canon Imagerunner ADV-C5800. This is a business printer, copier and fax all in one.  The machine is equipped with the IP FAX Expansion Kit and licensed.
Our setup includes  Call Manager - CUCM and a CISCO SIP Server. This machine has been assigned a DID extension and with the SIP is trunk to the PSTN.
To my understanding the machine is capable of : IP-Fax (Intranet), VoIP to G3 (via VoIP Gateway) and G3 fax.
The issue is the machine configurations requires VoIP Gateway setting where we used the SIP server and the IP of the machine on T.38 UDPTL connection as suggested by the manual.
Without any success the machine cannot register with CUCM and as a result cannot send / receive any external faxes.
What is working: Sending faxes to other faxes via Intranet, and the fax machine is able to call another external phone number but again no success with sending a fax to an external phone number.
I've been working with canon field techs / specialist without any success (not very experienced with SIP)
To eliminate some scenarios, we also have 10 faxes from another company running with the exact same setup and no issues (SIP via T.38 protocol with assigned extensions)
Searching for anyone who may have suggestions or have experience with this setup.
Thanks.
1 REPLY 1
Moderator
Moderator
Thanks for joining the conversation, mike11!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
Friends and Family
