How to turn off low paper warning - imagePROGRAF PRO-2600
Malle
How do I turn off low paper warning on Canon 2600 pro?
Right now it warns when the paper is low and stops printing, it used to keep printing until the paper was out for me.
How do I get this setting back ?
3 REPLIES 3
Patrick
Hi Malle,
If you select Printer Settings from the Home screen of your PRO-2600 and press OK, please then go down to Paper-related settings and press OK.  Are the settings that you are referring to "Roll amount warning settings" ?
Hej Patrick,
Roll amount warning settings is what I am refering to yes, but the minimum I can put there is "1 meter".
It used to just print all the way until the paper was out, but now I have to physically be at the location to press a button for it to print all the way which is non-optimal to say the least.
I would like to have the old setting back where it just prints all the way until the paper is out.
Patrick
Hi Malle,
Please turn off "Manage remaining roll amount":
1.  From the main screen of your PRO-2600, scroll down and select Printer settings.
2.  Tap Paper-related settings.
3.  Tap Manager remaining roll amount.
4.  Tap Disable.
