‎02-22-2024 12:49 PM
‎02-24-2024 06:59 AM
After all this was my fault.... I overused some WD40 inside the machine. There is a disk in the feed mechanism, and it got sticky after some weeks. All working now!
‎02-22-2024 01:44 PM
If you've already tried turning it off and back on, and it continues to display this error code, unfortunately you'll need to see about having it serviced (Canon customer service center). Refer to page 794 in the User Manual for details.
‎02-22-2024 03:01 PM
Turning it off and back on doesn't solve the issue....
‎11-29-2024 09:45 AM
Hello Eduardo
The same error code is coming up on my printer. Where can I locate this disk in the feed mechanism? I would be very grateful if you could tell me, I'm really stuck.
Thanks
‎12-02-2024 04:57 AM
On the left side oh the machine. Remove the cover and you should see the disk. Good luck!
‎12-03-2024 07:10 AM
Hello Eduardo
Thanks for getting back to me, I will try this, hopefully it works. Thanks
‎12-16-2024 05:55 AM
Hello Eduardo
I tried doing this, the disc does not look sticky or dirty. What else could be the problem?
Thanks
‎12-16-2024 12:41 PM
Don't know....
