.inf File Needed for SELPHY CP1300
cecep
Hi, I need .inf file for my cp1300 because I am already install on windows10, and  try looking  for that inf file but there is no directory or inf file contain canon printer
6 REPLIES 6
Moderator
Moderator
Hi, cecep!  If you're getting an error message regarding a missing file, it might be easiest to simply reinstall everything.  You can download everything you need for your SELPHY CP1300 for free right here.  Hope this helps!
cecep
Iam download again and try to install the installation process is success, and the printer is working fine. I need this extracted file to install driver into ultrasound machine thats wahy I need this file, can you give me or send me the file not exe file? thanks
You should be able to use winzip or 7zip to extract the contents of an .exe.
This is the contain of cp1300 .exe driver, try to add printer to my ultrasound there is no information contain for the device{printer}.
Iam still need the full extracted driver, pls help, thanks
you can get full extract at %temp% (canonUPW) after you installed exe file, you can copy CanonUPW and then add printer at your ultrasound
It's likely this was solved or abandoned.  There has been no activity on this thread for over a year.
