07-23-2026
09:16 PM
08:15 AM
James_C
New to this and having a problem with a Canon ImageCLASS MF753cdw printer/scanner.
It suddenly would not do anything. It would not print or scan. I called Canon Support and he was on the phone with me for more than an hour with resolution by installing the generic Windows print driver. I can no longer use the MF Scan Utility. I have to use Windows Scan App (which sucks). I'm not sure what changed. The Canon tech thought it was a problem with my router but I confirmed that is not the case by hooking the printer up to my Starlink and nothing changed.
My system:
Windows 11 25H2
ImageCLASS MF753cdw
Firmware ver 8.0
Connection is a wired network.
Any help appreciated
Thanks 73
Kent N6WT
07-24-2026 08:50 AM
Greetings ,
Using a generic print driver from Microsoft is limiting and does not allow you to fully utilize all of the printer's features.
I suggest you start over. You need two installers in order to get full functionality from the Printer under Windows OS.
Here's a link for the printer support portal:
The two installers you need are:
07-24-2026 09:33 AM
Thanks for the reply.
The tech from Canon had me remove everything as you described and use the Installer file you mentioned. I did not remove and reinstall the MF Scan Utility. The tech even had me delete the files folders at C:\Windows\twain_32.
After all was done, I can only print and scan via the generic Windows printer driver.
The router I have in the house is a Synology and the printer is hooked up to it via a wired connection. The tech was thinking that the printer was not communicating with the computer because of the router. After the fact, I setup my Starlink Mini dish next to my office and connected the printer and computer via Wifi. It still did not work. So I feel like that says it is not the router. Makes sense?
I will give it a go with the steps you describe. Give me a day or 2.
Thanks 73
Kent N6WT
07-24-2026 11:12 AM
Before proceeding, let's confirm communication.
Login to the admin portal of your router and view the list of attached devices. Verify the IP the router has assigned to the printer.
On your computer, open a command prompt and ping that IP address. Does it reply?
Do you have any third party antivirus software installed that might be affecting communication on your network?
07-24-2026 02:40 PM - edited 07-24-2026 02:41 PM
This is confusing to me. The router portal says the printer has two IP addresses.
192.168.1.206 seems to be for Wifi. While 192.168.1.216 is for the wired network.
I am not using the Wifi with the printer. If I ping that address, I get Destination host unreachable.
The wired IP is alive.
I only run Windows Defender for anti-virus.
