imageCLASS MF753Cdw - firmware update settings from web interface?
njsopitadmin
three brand new imageClass MF753Cdw printers at a remote location, all started prompting for firmware update. Anywhere to do this in the web interface (or better, anywhere to disable the prompt), or do I have to drive out there?
1 REPLY 1
pam244
Yes, you can likely update the firmware on your Canon imageClass MF753Cdw printers remotely via their web interface (Remote UI) by entering the printer's IP address in a browser and navigating to the firmware update section, often found under management or device settings. However, to disable the automatic firmware update prompts, you will likely need to physically access each printer's control panel at the remote location and adjust the update notification settings within the device's menu.
Friends and Family
