imageCLASS MF731Cdw Cannot use Canon Scanner on Windows 11
daveyp225
I have tried on three separate windows 11 machines. It is MF731CDW.
The printer cannot find my computer to scan too, and when using the MF utility,
I get the error
A scanner driver supporting this software is not installed. Install it and try again. 9,203,0.
I installed everything the same way I always do, and I have never had issues in the past. Complete driver package and then the scanner utility. Printing has always worked just fine.
Problems on Thinkpad, Surface pro 6 and my desktop computer. All the same thing.
20 REPLIES 20
YW, glad it worked.
Excellent. This also resolved the same issue for a MF242dw.
YW
DocBDC
This is what solved it for me. Read all the other replies and tried it all. Do make sure all the necessities are set up for MF scan utility: drivers, printer sharing on, windows firewall, correct install files for your model canon printer, do a ping request from the pc to your printer to make sure the network is working. So I noticed in the device manager, Canon MF632/634 and Canon MF632C/634C were both under the imaging devices tab. I followed another reply thread saying to disable both of them and then update them manually: right click->disable (both), then right click->browse computer for drivers->let me pick list of available driver->install the listed drivers. If you installed the correct drivers already, there should be an option there already. Just click next and it will update. When I did the aforementioned process steps with the Canon MF632C/634C, there was actually two options after clicking let me pick list of available drivers (Generic software device and Microsoft eSCL Class Driver). I think I chose the first option, generic software device, and after it updated, the Canon MF632C/634C moved from under the image devices tab to the software devices tab. If it did not move to the software devices tab, update the Microsoft eSCL Class Driver. Also, when this happened, both of them, Canon MF632/634 and Canon MF632C/634C, were re-enabled automatically. Not sure what that did, but it is now working on my laptop running Windows 11 24H2. I also have a desktop PC that is running on windows 10 which did not have a problem. Upon checking, it seems the issue with my laptop running on Windows 11 is the Canon MF632C/634C has to be under the software devices tab, which it was already that way on my Windows 10 PC. So, my guess is the software signature driver of the scanner driver has to be signed/be under the software devices tab and not just under the image devices tab where the Canon MF632/634 is. Hope this helps.
It works! Thank you!!!! Someone please bump this solution for everyone to see.
AK2024D12
Unfortunately it did not work for me for MF735CDW. Will have to keep on looking.
Windows 11 just came out with an update. You may want to update your computer than uninstall and reinstall drivers and see how that works.
Registry Fix worked for me running fresh install of Windows 11 24H2. imageCLASS MF269dw. Posting for other people that might find this thread having the same issues. Thanks!
Bulletproof
First the printer no longer would connect to the pc via USB.  That's still the case, but it is now connected with wifi.  But no scanner?  Couldn't be found.  I fought this for two days.  Tried all the updated and deleting and reinstalling drivers, and restarting the pc and the printer.  Maybe some of that helped, but didn't work.  The thing that got the scanner back on line was this:
  Courtesy of Google AI
Verify Windows Image Acquisition (WIA):
  • Check WIA Status: Search for "View local services" in the Start menu, find "Windows Image Acquisition (WIA)," and check its status and startup type.
  • Ensure it's Running: If it's not running, right-click it and select "Start".
  • Set to Automatic: If it's not set to automatic, change the startup type to "Automatic".
    And it worked!  I had to changed the scanner software I use to WIA from Twain, no biggie.  Didn't even have to restart anything.  I still have no idea what a WIA is, but mine is now automatic.  I'd still like the USB connection to start working again.  Maybe tomorrow?  I'm up to the challenge.  😁
Quit working again.
