11-29-2020
06:40 PM
08:34 AM
James_C
I have been struggling to get this printer to work consistently on my network from my MACs. Most of the times when I try to print, I get an error.
Opening the Settings --> Printers and Scanners --> Canon 644c,
The banner says that the printer is offline.
Under the print job I get the message Priner - Unable to find printer
None of the macs can consistently print using the print function.
Anyone else face the same problem?
11-29-2020 09:55 PM - edited 11-29-2020 10:03 PM
I have the exact same issue with a Macbook Air with a MF641Cw !! We have removed and reselected the printer many many times as we thought that this sometimes worked. Right now, I am installing the latest firmware update - something about a monitoring server, related to proxy authentication - whatever that is. We can't be the only ones having this problem and its a serious one!
12-24-2020 07:15 PM
Exactly the same problem. I have the same situation. The printer will occassionally print but it takes at least 10-20 minutes for the Macbook to find it. Often it doesn find it at all. The PC connects and prints just fine. I have been at this all day. Very frustrating
01-05-2021 12:56 PM
Hello kaushikn,
If the Macs keep losing connection while other devices are still able to communicate, it could be caused by signal strength or a network communication issue. If the printer is on WiFi, ensure the MF644Cdw's signal strength is at least at "Good."
<Status Monitor>
<Network Information>
<IPv4>
Select the setting to view
Check the settings
If the signal strength is poor, you can try moving the printer to see if it gets a better signal. If the signal strength is good, you can try refreshing your network connections by unplugging your router from the power for five seconds. Once the network is back up, you can try printing again to see if it responds from the Mac.
To provide additional information or to provide other options, we would need some additional information. If you could reply to the message with the information below, we would be happy to assist.
01-05-2021 01:14 PM
Hector: Thanks for the advice but I'm still having the same problem. The signal strength is strong (same room as router).
The Mac won't wake up the printer from sleep mode. I just get an error: "The printer may not exist or is unavailable at this time." One must physically walk to the printer, turn it off and on, and print.
I haven't tried scanning yet. I will try that if I can get the printer to work.
Mac OS 11.1.
01-05-2021 01:19 PM
FWIW, after I installed the latest drivers/firmware, I couldn't locate the printer at all from the MAC. I forget the option to do this on the MAC, but I knew the IP address of the printer as I had dedicated it on my router. I told the driver to use that IP address - low and behold it worked and I've haven't had a problem in two weeks! Fingers crossed. Hope this helps.
01-06-2021 10:41 AM
Hi Hector -
Thanks for responding.
kaushikn
01-07-2021 01:12 PM
Same problems. No help from Canon. Today is my last day to file a return for the printer. I have opted to send it back and purchase something else. I will not forget what a terrible experience this was.
02-22-2021 08:50 PM
02-24-2021 05:10 PM - edited 02-24-2021 05:15 PM
I'm having the same issue with my brand new MF743Cdw on two different versions of MacOS (11.2.1 and 10.15.7)
One difference with mine is that the printer is connected via Ethernet, not WiFi, so there's no way it's a WiFi signal issue.
I have no issue setting up the printer, but it goes offline after the printer goes to sleep and the Mac can't wake it up to print. What's really odd is that the scanner still works even though the printer says it's offline. I can switch to the scanner in Settings > Printers & Scanners. But even scanning something doesn't bring the printer online.
I've tried resetting the printing subsystem and I've removed and readded the printer numerous times.
