06-05-2023
11:22 AM
08:44 AM
James_C
I was having problems printing with my ImageClass MF4890dw printer, so I uninstalled it from my Windows 11 settings and downloaded the appropriate drivers from Canon's website.
When I tried to reinstall it, the installation begins to start but then I get this message,
"ScanGear is currently opened. Close the ScanGear window and run the setup again. If you do not have ScanGear open, it may be opened by other users on this system. Close all ScanGear windows and then try again."
I have closed anything and everything that I can see that maybe causing this an still I get this message everytime I try to reinstall my printer....
06-05-2023 12:33 PM
Note that I currently don't use any Windows computers, but remember dealing with similar situations in the past.
First thing to try is a reboot if you haven't already. That should stop any rogue processes that may have ScanGear open.
Beyond that, you may have to see if there are any Windows services that are running. Check for any service with "Canon" or "ScanGear" in its name, then stop those services. After installation of the software, restart the services you stopped. Or, reboot (which should restart them).
06-05-2023 12:53 PM
You can also terminate any program or process using Task Manager. Just right-click on a section of the task bar where there are no icons and select Task Manager from the context menu.
07-29-2025 08:24 PM
How do you stop or correct that issue when ScanGear is not installed on your system.
07-29-2025 08:26 PM
I have the same issue. Did you get this resolved? I don't even have ScanGear on my pc.
07-31-2025 10:46 AM
Hello RND,
Thanks for letting us know what Canon product you've got. The imageCLASS MF4890dw is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
07-31-2025 12:04 PM
Ron, I did not provide that information. Your post is not relevant to mine.
07-31-2025 12:07 PM
Hi there,
Are you using the same printer? If yes, sorry it has been retired. If no, please create a new thread with your specific details so it can be addressed! Here's how to create a new thread if needed.
Hope this helps!
