05-02-2024
08:54 AM
09:01 AM
I have several Canon MFPs, a mf452, a MF751, etc. These printers come with a WIA driver that is not stable in my scanning application. Does Canon produce TWAIN drivers for modern MFPs? If so, where can it be found?
04-02-2025 10:57 AM
Hello,
We do have twain drivers for that model. You can download the MF753Cdw/ MF751Cdw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear) from our site using the link HERE. The scangear portion of the install, will be the twain driver. You can also download and install MFscan utility from the same page. It is the scanner software that works with the twain driver.
04-23-2025 02:46 PM
Hello
i tried to connect my Canon MF452 DW printer to lap top with USB cable, nothing happening, can mot connect printer to my lap top, any hints
04-23-2025 02:48 PM
Why is not connecting my MF 452 DW printer to my lap top ?
04-23-2025 02:48 PM
What driver i need to install for my canon MF 452 DW?
04-23-2025 02:55 PM
Thanks for joining the conversation, patel27!
You can download everything you need for your imageCLASS MF452dw, including the driver, right HERE. If you continue to have trouble getting your printer set up on your laptop and it's a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
