imageCLASS MF445dw MF Scan Utility Ver.1.20.0.2 download link broken
daveincamas
When I try to download the MF Scan Utility Ver.1.20.0.2 from this page, it tries to go to https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNjMwMTA2&cmp=ABR&lang=EN which gives a 404--Not Found error.
adidosc
I ran into the same issue. I ended up downloading it from Canon India and it worked.
https://in.canon/en/support/0200686804?model=1418C013
7 REPLIES 7
Tiffany
Moderator
Moderator
Welcome to the forum!
To access MF Scan Utility, please try to this link: https://canon.us/3OiLrXt
From there, click on Software & Drivers
adidosc
Thank you Tiffany, however I get a 404 from that link as well.
Greetings ,
Tonight I also noticed that v1.20.0.2 link was broken on the support portal for the MF644Cdw.
However,  v1.21.0.2 is available on the same page about 2 lines down.  MF445/644 and others. This version is about 9 months newer.  I moved my MF644 to a different machine tonight and used it without any issues.
Same 404 not found error from that link as well
Please clear your cache and cookies, as we double checked the link and it is working on our end!
Please also note, there is a new version out, 1.21.0.2, which you can see at the bottom of the download list.
Friends and Family
