imageCLASS MF4350d unable to print from Windows 11
canonkl
I tried to setup printer Canon Imageclass MF4350d to my laptop with Windows 11.  I downloaded the printer driver from the Canon support website.  The printer did not print and has "Error" status although the scanner works fine.  Does anybody know what wrong with it and how to fix it.  Thanks!
8 REPLIES 8
mreg
Rising Star
I don't have an answer for you, but if you put something more descriptive in the title other than just the name of the printer that might help.
Spotty
Had the same problem with my Imageclass MF-4350d and installing the correct drivers for Windows 11.  Tried everything.  Finally located the driver that has worked for my windows 11 system.  It is meant for windows 10 but has worked very well for windows 11.  The driver name is "Canon MF4320-4350 Version 2.7.0.0  11/5/09"  Once the driver has been downloaded then try installing the printer thru the Device Manager or the Add Manually option in Windows 11.  When using the "Add Manually" option select the "My printer is a little older, Help me find it" and "Add a local printer or network printer with manual settings" options and follow the prompts.  Hope  this works for you.
It worked.  Thanks so much for your help!
Thanks, but how do you find and download "Canon MF4320-4350 Version 2.7.0.0 11/5/09" driver?
I cannot find any reference to it in searches that I have done.
Regards
Hector
Hello,
You can find the last version of the drivers using the link HERE. In the operating system selection box, you would need to switch the OS to Windows 10.
canon007
Hello Hector, the link provided shows the latest for the OS specified, but we need version issued Nov 5 2009.
Any ideas?
I was not able to find it, so I kept going down the version list until I found one that worked for me - Vista 64 on my computer.
rwill
Thanks Waldy, I actually got a computer guru to get it working for me, but now the scanner won't work for me after the MF toolbox disappeared somehow!
Friends and Family
