imageCLASS MF264dw II scanner driver error on Mac, OK on iOS devices
tgruben
New mf264dw II, setup and printed fine on my m1 max mac running latest sonoma 14.3.  I attemp to use the scanner, that should up in the network settings and has a green "light" icon.  But I recieve the following error..
Cannot communicate with the scanner.
The cable may be disconnected, or the scanner may be turned off.
Check the scanner status and try again.
Scanner driver will be terminated.
Error code: 600104
Any hints? One thing, it scan's fine from the cannon IOS PRINT app
0 REPLIES 0
