imageCLASS D420 windows 11 driver???
ffejvt
Hello.Just purchased a new Dell tower and am bummed that my trusty imageCLASS D420 will not work with windows 11(at least i don`t think as i cannot find an 11 driver.Much obliged if anyone knows a way i can get them to communicate.BIG thanx!
21 REPLIES 21
I finally got the printer to work. The computer did not find the printer when I plugged it in, but I found a location where the program asked which port was used, and when I typed in the correct USB port, the printer was recognized. I do not remember where I found that instruction.
Addition by JustDon: My problem has been solved.  Here is what I think I did wrong.  First, I had the printer plugged in to the PC and turned on when I ran setup.exe to install the drivers.  Second, I tried to install it in LPT1, the parallel port when it needs a USB port.  With the drivers improperly installed, there was no choice of a USB port.  Properly installed, a port named USB001 was added to the port list. An aside:  I read that some older printers can't run on the new high speed USB ports, but after I installed it in a USB 2.0 port, I moved it to a "super speed" usb port and it worked fine.  So yes, the ImageClass D420 can be installed on a Windows 11 PC (mine is a HP Pavillion) using the Windows 10 drivers, as Hector said, but if you don't install them correctly, you may mistakenly conclude it won't work.
Awesome that it is working in Windows 11.  I am trying to help my Dad set up his new Dell Precision workstation (Win 10 Pro 64 bit) with his old ImageCLASS D420.  We were able to get the ToolBox for scanning to work but after 6 or 7 attempts, we can not make Win 10 PRO 64 bit recognize the printer.
We have made sure to keep the printer unplugged from the tower while running the setup wizard.  I have tried deleting the downloaded drivers and re-installing several times and have made sure to restart Win 10 Pro 64 in between attempts.  When I check the device manager, the printer will not appear but an unknown device will appear with the time stamp of the running of the setup wizard. When I try to update the driver for the unknown device by browsing to the folder that contains the drivers downloaded from the Canon support page, Windows says that it can not complete the driver update.  Are there any other tips or tricks to try get the printer working on Win 10 PRO 64bit?  I have also tried doing the 32 bit version of the UFR printer driver but the setup wizard gets interrupted and won't proceed because of the 64 bit Win environment on the workstation.  When I view the Printers and Scanners page (launched from the control panel) I see a Laser Multifunction printer installed but it does not allow for printing and I do not have the option to set it as the default printer.  On all of the PCs at my house, I can see my Canon devices by name (for example: Canon MF3010 or ImageClass D242) listed instead of just the generic term "Laser Multifunction Printer".  Thanks in advance for your help!
How to get ImageClass D420 Print function to work on Windows 11
1. Download print drivers for Windows 10 (imageCLASS D420 MFDrivers)
2. With Printer turned off, install the MFDrivers.
3. Now turn your Printer back On and make sure it is connected to a USB port or step 4 won't work.
4. Will need to add the printer manually. Go to Windows "Printers and Scanners", Click on Add Device, after a few secs you should have option to click on "Add manually", click on Add manually, Select "Add a local printer or network printer with manual settings", Click Next, Make sure "Use a existing port" is selected and click on dropdown to select "USB002 (CanonD400-450 (UFRIL LT))", main thing here is to select the port that has your Canon listed, Click next, You should see Canon listed under Manufacturer, Select Canon and then under Printers select "Canon D400-450" click Next and make sure this option "Use the driver that is currently installed" is selected, Click Next, Choose a Printer Name, Click Next, Printer Sharing is up to you, click Next, Then Click on Print Test Page, Note if this doesn't work you just need to power off your printer and power it back On.
Without your solution Hector I would not be able to print again.  Just scan and copy.  I have Windows 10 64 bit and do appreciate your suggestion.  I followed it.  And it worked.  Thousand THANK YOUs.
  • Greetings. I followed the instructions and selected Windows 10 but the D420-450 is not an option to select. I also checked the windows update and there is not a D420 option. I have a Samsung Galaxy Book 3 with Win 11. The control panel device & printers shows a laser multifunction printer.
Thanks in advance. Chet
I found that WHENEVER Windows does an update, I CANNOT get the ImageCLASS D420 to print.  All it does is want to Fax, which I DO NOT need.  I really truly need the print option.  Especially for medication ordering and other things.  So. please pass the words on that LOYAL CANON users are STILL having problems and will continue to let CANON know about them.
Ron
Moderator
Moderator
We're sorry to hear about the problem.  The imageCLASS D420 is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
This solution does not work. Too bad, it was a great printer. Typical technology - "progress" comes, everything that worked fine is no more until I buy an over-priced under-featured solution that cannot hold a candle to the old one. Print prompt says "ready" on MS Word, click print and....... nothing. Printer just sits there in ready state, print queue on computer says nothing more than "Error." Please advise, if you care to. Apologies, tech dysfunction is soooo frustrating to an old person like me who grew up when stuff simply worked.
When I try to download the driver specified it only list the "Toolbox". When I install the Toolbox and try to run it I get the message "a supported scanner is not installed. Please install a supported scanner and restart Toolbox"!
Is there a way to get the D420 driver off my old windows 10 pc and install it on the new Windows 11 pc?
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
