iPad won't connect to mg2922 printer
jpspencer
My MacBook Pro is connected to my wifi network and I can print directly to the MG2922. However, I cannot connect my iPhone nor iPad to the printer. I am using OS 15.2.1. I have also downloaded and tried using the Canon App. I get the error message "No AirPrint Printers Found." The network config page from the printer also shows a status of "Active." Any suggestions?
1 REPLY 1
The MG2922 does not support Wi-Fi Direct printing.  You must connect it to a wireless network.  Then any other devices connected to the same network will be able to print to it.  You can perform cable-less set up from a computer, or from the Canon Print App, but the printer has to connect to a network before you can print.
