Windows 11 drivers needed for outdated PIXMA MG3650S
WhidbeyIsland
I have a used Canon PIXMA RMC K10425 wireless printer that someone gave me. I don't have an installation disk. My PC is old, but it does run Windows 11. I can't find drivers or downloads on the Canon website (it doesn't even recognize the model when I try to register it) and I can't find available ink. My PC doesn't recognize the printer and won't allow me to add it manually. I'm not sure how old the printer is (10 years?) but am I correct in assuming it's too old to use? I'm pretty clueless when it comes to things like this.
6 REPLIES 6
Tiffany
Moderator
Moderator
Welcome to the forum!
This model number doesn't appear to be a Canon USA printer model. Please double check and let the community know the exact printer model number.
Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you.
I'm taking the information off the back of the printer. If I could attach a picture you'd see the outside branding is a Canon Pixma. I've done a Google search and there was a 3/16/2021 question on justanswer.com where someone references the same wireless all-in-one printer model RMC: K10425.
The PIXMA printer model number should be located on the front, top or near the panel.  Canon printer models usually have model names that begin with 2 or 3 letters--such as iP, MP, MX, MG, TR, TS, G to name a few, followed by numbers.  Once you find this, you will have found your printer's model number.
Does this resemble your device?
frostythedemon
This is like, nearly a year old at this point - but I have the same printer with the same serial number. It's a Model MG3650S
Hello, and welcome to our Community here at Canon USA!
The printer you mentioned isn't a model we sell or support in the United States, so our team has no information on it.
If you're outside the US, you'll want to contact Canon in your country or region for support options. You can get started at https://global.canon/en/support
I hope this helps point you in the right direction!
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
