ToolBox4911mf18WinEN defaulting to french
cgfourman55
When attempting to scan with the MF toolbox and selecting the "Display the scanner driver", the scan driver is in French. I have removed all drivers as well as software many times. Between each reset, I use AVG to scan the registries, repair any links or shortcuts then restart the computer. no matter how many times I try, the scanner driver is defaulting French, and I don't have the desire to learn a 4th language. I even scanned the registry editor into the registry editor to find a way to change the language pack and there is nothing there.. any suggestions?
2 REPLIES 2
Moderator
Moderator
Thanks for joining the conversation, cgfourman55!
So that the Community can help you better, we need to know exactly which version of Windows is running on your computer. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
cgfourman55
thanks , system specs are as follows, and the printer is on a USB. here is the sys specs and the information in "french" of scangear MF
Avatar
