PIXMA TS6240a printer - connection fails
SquireDude
Windows 11 25H2
Pixma TS6240a
I am unable to connect via USB or Wi-Fi.  Tried connection via IP and Auto-Connect.
I have rebooted the laptop as well as the printer to no avail.
I am at my wits end and my frustration level has reached an end.
I need help please as I am unable to print anything at this time.
Thanks
1 REPLY 1
DerrickL
I suggest you start from the beginning. Use the USB printer cable and if you want you can convert to a WIFI connection in the future. Disconnect the USB printer cable from the printer, use the link I posted,  choose software and drivers and download the full printer and scanner driver setup package at the bottom of the page, run it and connect the printer cable when prompted to do so. Once done your pc should see the printer and you can   install other software on the support page, The IJ Printer assistant tool will have printer maintenance functions.
https://www.usa.canon.com/support/p/pixma-ts6420a
Friends and Family
