PIXMA TR4720 does not connect to internet
JLP1
Is there any way to change the setting on the TR4720 to display an internet password being entered during setup? Currently the password is masked with ****. My new router has a very long, complicated password which I have attempted to enter many, many times - each resulting in a request to re-enter the password. With the mask, I can't tell what the error is.  Any suggestions?
JLP1
PS  The cable worked one time and then didn't work either.  I finally went to the APP store, downloaded a free Canon printer app, accessed the printer and reset the password.  IT WORKED.
6 REPLIES 6
Patrick
Hi JLP1,
There isn't a way to disable the mask when entering the password for your Wi-Fi.
There are other ways to connect.  Does your router support WPS?  If so, you can quickly connect your PIXMA TR4720 to your Wi-Fi using the WPS method:
PIXMA TR4720 - Set Up the Wireless Connection Wi-Fi Protected Setup (WPS) Push Button Method
I followed the instructions and keep getting a timeout error. I select the WPS Connect selection on the printer, then I press the WPS button on my Verizon router for 5 seconds, then I press the OK on the printer. It says Connecting..., then it times out. The printer and the router are about 12 feet apart with no obstruction between them. What next?
Try this: https://canon.us/TR4720setup
After you hit next, go to option B
Thanks...but I just bought a cable to attach to my computer and am now connected.  Of course that only connects to one computer, not to everything on my network. I'll just figure out a work-around if I need to print from another device.
JLP1
I do appreciate your rapid response!!!
JLP1
Avatar
