[SOLVED]ip address filtering reset-PRO-100
lissa374bq
How do I reset the "IP Address Filtering" in the "Network Configuration"? Am attempting to connect the printer via a wired ethernet connection from a router. The address set in the printer's network configuration is currently set incorrectly; I, therefore, can not connect to my PRO-100 except via USB.
Box is a Windows 7 x86OS. Printer is V1.0.3
Re-running the installer, which came on the OEM CD installation disk, did not help.
If any particular information from the "Network Configuration Page" is needed, I will, of course, supply it.
0 REPLIES 0
