10-21-2024 12:22 PM - last edited on 10-21-2024 11:01 PM by Mike
Can't get my new TS30a to connect to the WIFI. Works fine using USB connection to my Macbook but I would like WIFI connection. Manual is useless. Sends me to a webpage that is outdated.
10-21-2024 12:41 PM
Hi there!
Can you please double-check the model of your printer? It'll be listed on the top or front of the unit.
10-21-2024 01:48 PM
Typo above. It is a TS302a
10-21-2024 01:57 PM
Thanks!
You can get the most current version of the software HERE.
You can find the support page for your printer HERE. I also recommend registering it at https://canon.us/account, so you won't have to dig around for the software or manuals next time you need them!
10-22-2024 11:01 AM
It's not a driver problem, it's a problem connecting to wifi. I think Rmldt1107 has the right answer.
10-21-2024 09:47 PM
Can you switch your wifi network from 5GHz to 2.4GHz? I had the same problem trying to connect it for over an hour and it wouldnt show up on my phone until I switched my network to 2.4GHz. Not the same model but it's worth a shot.
10-22-2024 11:04 AM
I think this is the answer although I'm not wanting to screw with my router to make it work. I can live with having the printer connected via USB for my needs. It's only a $70 printer. Just disappointing Canon cannot anticipate having these kinds of issues and adjust their products accordingly. Thanks for your suggestion.
