10-22-2023 11:44 PM
After changing wifi networks, my printer sees the new network, tries to connect, but fails. It never asks me for the passphrase after I select the network, which leads me to believe it's using the old password from my old network. I performed the "Reset LAN settings" in the device settings menu, but it still won't prompt me for the password. Is there ANY way to change the wifi network password on this giant paperweight?
10-23-2023 10:12 AM
If you re-run the set up program, it will give you the option to update/change the Wi-Fi network and/or password for the network. This will allow the printer to connect to the new network.
10-24-2023 11:22 AM
I have re-run the setup program, several times. I've "Reset LAN settings" and "Reset all", then run the setup. I use the "standard setup", as my new network - a T-Mobile gateway hotspot - doesn't have a WPS feature. It finds my home network, no problem. But when I select that, it shows "searching for access point...". After 10-15 seconds, and no password prompt, it beeps and replies with
"Error
Failed to connect to the access point.
Follow the steps below.
If the same error occurs, see the access point manual and check the settings."
I've tried wireless - which worked fine with my old network, and also USB wired. There's never a prompt to enter the new password. So, either it's still using my old networks password, or isn't detecting that my new network requires one. I've had this new T-Mobile gateway for a couple of weeks now, and every device in my home connects to it no problem, so it's not that. I just need some way - that actually works - to completely reset reset the printer. The "Reset LAN" and "Reset all" haven't worked. Also, Canon seemed to go out of their way to delete ANY drivers or setup programs from their website for this model, and won't talk to me at all unless I pony up more cash. I guess they figure if I have to buy another printer, it will be a Canon...? Uh, doubtful, given the customer service - or lack thereof.
10-24-2023 11:47 AM
Hello there!
You can find your personalized support options within your My Canon Account at canon.us/account
I am not a tech, but I have some experience with T-Mobile Home Internet, and this sounds like it's an issue of your T-Mobile Internet Gateway not being able to see your printer.
THIS IS NOT OFFICIAL SUPPORT FROM CANON
Your printer can only see 2.5Ghz networks, so you need to make sure your T-Mobile Home Internet (TMHI) is broadcasting both networks, so open the T-Mobile Internet app and tap the Netowrk tab along the bottom. You'll see your WiFi name along with Frequency band "5Ghz, 2.5Ghz, or Automatic" - for the printer to be seen, it needs to say 2.5 or Automatic. If you want the fastest speeds, put it on Automatic. If it's broadcasting both networks, then should be good.
Now that you've done that, you should be able to follow THIS article to manually connect your printer to your T-Mobile Internet Gateway.
10-24-2023 06:51 PM
My T-Mobile gateway is set to "automatic" (has both 5Ghz & 2.4Ghz). My printer is seeing my network. My network shows up right away, at the top of the list, so the printer is seeing it. The problem is that when trying to connect to the network (which it never has) it doesn't prompt me for the password. The password has never been entered on this printer, so it needs to be, in order for it to actually connect to my password-protected network. If the printer setup won't give me an option to enter the network's password, how can it connect?
10-24-2023 07:07 PM
10-24-2023 10:01 PM
Yes, those instructions are exactly what I've been doing. Over and over. But, in those instructions, as in all others I've found, selecting your network brings you to an alpha-numeric password-entry page. When I do this, that password-entry page never appears. What I need is a way to enter the password, an the normal printer setup won't let me do that.
11-19-2023 05:53 PM
I am having the same experience. In my case, I changed the password of my T-mobile home internet gateway and now need to make the same change on my MX920 printer. The printer just fails to connect just like yours and never allows me to enter the new passcode.....
11-19-2023 11:51 PM - edited 11-19-2023 11:51 PM
Yeah, it sounds like no one - not even Canon - has any clue of how to manually enter the wifi password into the printer settings when the auto-process won't do it.
I gave up. I bought an Epson to replace it. Works great. Too bad, as I had been a Canon man (printers and cameras) for decades.
06-03-2024 07:11 PM
I was having this same problem, but I managed to resolve it. I just got the T-Mobile gateway. I did two things, but it's working.
1. I created a second network with the Frequency Band set to 2.4 GHZ and the WPA Version at WPA2
2. Then I went and reset all the LAN Settings
3. I went through Standard WiFi Setup, selected the new network I created and the Password screen came up
4. I entered the password and connected to the printer
5. I printed a document from my computer successfully
I hope this helps.
