PP&L image size adjustment issues for cut sheet paper
wicked1
Please explain why PP&L will not allow me to adjust the image size using my number pad when printing to cut sheet paper while that option is allowed when using the roll feed? This makes NO SENSE whatsoever as the sliders are the only option available when using cut sheet paper and they are WAY, WAY too sensitive to any adjustments!
It's virtually impossible to make fine adjustments to the image size on cut sheet paper using the sliders!!
1 REPLY 1
Sonya1
Hi wicked1,
The settings in Professional Print and Layout are more flexible when printing on roll paper. As you have seen, your option to adjust the image size using your number pad is not available when using cut sheet. I suggest you create a slot size then add the image to the slot for fine adjustments. I hope this is helpful.
