04-09-2023
08:48 PM
10:13 AM
Unable to find/install driver for the printer.
This is what download:
I followed the instructions several times to no avail. It will not print the test page or anything else. Could not see any error code on the printer display.
These are the only drivers/software info I found when trying to install:
None of them worked.
04-09-2023 09:58 PM - edited 04-09-2023 10:01 PM
What version and build of MAC OS is the printer being used with or installed under?
04-10-2023 07:44 AM
Hi Rick,
I'm using Sierra 10.12.6 OS. Know it's old but so is my editing/graphic software (and me too).
Is there an older download lying around anywhere?
Thanks.
04-10-2023 09:19 AM
This is the download I found for your device and OS:
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNTg3MjAx&cmp=ABR&lang=EN
I suggest you remove the printer from Apple menu > System Properties > Printer and Scanners
Then remove the failed installer from the applications folder. If you happen to see any remnants elsewhere, remove those as well. Then restart
If the printer is connected via USB, do not connect it until prompted by the installation software.
04-10-2023 09:52 AM
Thanks you Rick. That did the trick. Have a great day!
