02-17-2025
05:47 PM
10:27 AM
Installed Canon TR4700 Printer/scanner and when using Image Capture (Mac OS 13.7.3), message notification is no camera or scanner selected.
02-18-2025 09:53 AM
Thanks for joining the conversation, bruce334!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TR4700 series. The model number should appear on the front of the unit at the upper right. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-18-2025 10:25 AM
Printer is Canon Pixma TR4720
02-19-2025 04:48 PM
Hi bruce334,
Please attempt to scan using the IJ Scan Utility.
If you do not have it installed, it is available here:
Canon Support for PIXMA TR4720 - Downloads
If you are unable to scan using the IJ Scan Utility, what error appears?
Are you using your TR4720 wirelessly?
or with a USB cable?
03-22-2025 11:56 AM
Problem continues. I'm using a Pixma TR4720 printer with Mac OS 13.7.4. In system preferences, printer does not appear. When I try to add printer, screen advises, driver needed. TR 4720 not listed in available drivers. I've downloaded and installed all available software for TR4720 from Canon website. Only Scan and Fax TR4720 appear in printer and scanners in system preferences.
03-22-2025 12:00 PM
Did you download and install the Master Setup software from the support page?
03-22-2025 01:49 PM
Yes, set up downloaded and it indicates printer is connected (via USB), but printer doesn't appear in Mac OS system preferences.
04-23-2025 05:19 PM
Using canon TR4700 series 2 with driver 3.0. Utilizing wi-fi connection. Printer/scanner also doesn't appear in IJ Scan Utility. Using Mac OS 13.7.5.
04-24-2025 06:28 PM
Yes, downloaded and used the Master Setup using USB connection. Printer appears in Master setup, but get a connection error when trying to print or scan. Checked connection cord is installed and printer power is on.
04-24-2025 06:30 PM
In Sys settings>Printer & Scanner, Canon TR4700 series 2 shows as default printer and in idle state.
