PIXMA TR4550 wired (ethernet) connection option
Grenouille
Hi there
Is this possible? I've connected the printer via ethernet cable, but it's not showing up on my network. I've scrolled through the printer's setup menu, but there only seem to be wi-fi options.
Any help appreciated
10 REPLIES 10
normadel
You apparently do not know the difference between an RJ11 port, which is for a phone/fax line, and an RJ45 port which is for an Ethernet cable. RJ45 is wider, but an RJ11 plug will go into it and will do nothing.
Your printer does not HAVE an RJ45 port. So you cannot use wired Ethernet. Only WiFi.
Friends and Family
