‎04-14-2016
12:11 PM
‎08-20-2022
09:39 AM
Hi there,
I have a Canon MX472 and am running Windows 10. I set up my printer on WIFI and it's worked fine before, but now when I try and scan, it's saying "PC not Connected". But I can print from the computer just fine. Any help on getting this matter fixed would be greatly appriciated!
Thanks,
Sean
‎08-05-2020 01:23 PM
Me too. How do I fix it? trying to scan from 3 different computers ... all same message
‎10-07-2020 07:56 PM
I've had this problem also - will print - will not scan as of this week afrer months of use.
I can get the scanner to work if i use the windows 10 scan app but not using the usual cannon software
‎11-01-2020 02:46 AM
I fixed my problem. After downloading the driver installation file for the 4880dw printer on windows 10 the printer began to print but would not recognize the computer I wished to scan to. After much google study with no clear result on how to solve the issue, I just happened to locate the original user software disk that came with the printer and was used to orignally connect my other computers successfully. I ran the software that included and apparently loaded the MF toolkit. Voila! my new computer was recognized for scanning on the printer.
‎01-20-2021 05:06 PM
Like everyone else on this message thread, my scanner quit functioning within a few weeks of setting up my G7020 printer with Dell Computer with Windows 10.
This is my first venture with Canon, after being a long-time HP customer. So far, this has been a big mistake. It took me hours just to get my printer set up with my laptop. The Canon manual and the responses from the Canon help desk have not helped. Fortunately, the responses from other customers with possible work arounds have helped the most.
Still it hasn't fixed the problem. I noticed the first message was from 2016, and 4 years later, Canon still doesn't have a solution? I couldn't be any more frustrated. I had similar problems just getting my printer linked to my laptop. Time is money, and trying to get this printer to work has cost me so much.
‎01-20-2021 07:40 PM - edited ‎01-20-2021 07:43 PM
I had a problem of no scanning with Canon 4880dw on both windows 7 and windows 10 machines. The printer worked. Downloaded and reloaded drivers from Canon website without success - until I found the original disk that came with the printer. When I attempted to reload the driver from this disk it said the driver was already loaded but the Canon Toolkit MF Network Scan Utility\CNMFSUT6.EXE did not seem loaded. After I loaded it - voila scanner recognized computers. So get the disk that came with printer or ask Canon to supply this utility...
‎01-21-2021 11:36 AM
Thanks for suggestion. What is frustrating is to make your solution work, I now have to purchase an external disc drive for my laptop.
I cannot believe how much time I have spent to get this Canon all-in-one copier set up and it still doesn't work for the most important purpose for which I purchased it. This has been an ongoing issue for Canon since 2016, per this thread, and they still have not come up with a solution for us to not have to keep erasing the software and then downloading it again?
I really appreciate your responding to my message. I will try to follow your suggestion if that is my only solution.
‎01-21-2021 08:34 PM
‎01-25-2021 03:40 PM
Thanks for that heads up. I will look at this and see if this fixes the problem. I appreciate your assistance. Very considerate of you. Thanks, Patrick
‎01-28-2021 12:28 PM - edited ‎01-28-2021 12:32 PM
I had this printer for years now. Needless to say, I had the exact same problem. Printer over WiFi works fine, but when you try to scan, sometimes work, most times wont.
I tried everything, reseting drivers, diferent computers, conected the printer near my WiFi router, disable ports, firewall, nothing woked... (conection over USB cable works but I have no space near PC).
So I check youtube and found a guy with the same problem. He did not fix it but found a way around it.
Basically, download another scan software!!! THATS IT
GO to windows store and search for 'Windows Scan" Is free and it works all the time!! So this is most likely a bug in the canon software.
The only down side I can see is that it doesnt scan to PDF. But if this works I would guess any third party scan utility should work.
This is the link for the video.
https://www.youtube.com/watch?v=7XeG6tnc_6Q&t=121s
Hope it helps!
