11-17-2020 10:53 AM
I reset Windows 10 last week and now I can no longer set up my printer wirelessly. Have tried to do so in three different ways but none has worked. LAN is set to Private. I've searched extensively and have found no one else who has encountered this problem. Local computer repair shop had no theories. Printer works fine wired. Any help would be greatly appreciated.
12-17-2020 01:02 PM
Hi artspolice,
You can try the WPS method of connecting your PIXMA MX420 to your wireless network.
There may be a physical button on your router that you can press to enable this or you may have to log into your router's web interface to perform this. Please check your router's documentation for further details.
To perform the WPS setup for your PIXMA MX420, please follow the steps in this article:
https://support.usa.canon.com/kb/index?page=content&id=ART112415
12-17-2020 01:02 PM
Hi artspolice,
12-17-2020 02:19 PM
Thanks very much. Got this same advice from a printer repair shop and it solved the problem.
