02-06-2016 09:31 PM
08-27-2019 04:11 PM
I have seen issues with attempting to connect to Hitron routers.
The only method that seems to work is to use the WPS PIN method.
To do this, please follow the steps in the following Knowledgebase Article:
https://support.usa.canon.com/kb/index?page=content&id=ART173530
02-08-2016 12:03 PM
Hi bcomito,
To set up your PIXMA MG5720 on your wireless network, please follow these steps:
1. On your PIXMA MG5720, please press Setup from the HOME screen.
2. Select Device settings and press OK.
3. Use the up or down arrows to select LAN settings and press OK.
4. Use the up or down arrows to select Wireless LAN setup and press OK.
5. Select Other setup and press OK.
6. Select Advanced Setup and press OK.
7. Select your access point (router name) and enter your wireless password. Please make sure that the password is corrrect. The password is case sensitive, if entered incorrectly, your PIXMA MG5720 will not connect to your wireless network.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
07-21-2016 01:05 PM
Thank you for the information.
I followed the steps but after I get to "Other Settings" there is no "Advanced Settings" option. I can choose from:
Set Printer Name
TCP/IP Settings
WSD Settings
Bonjour settings
LPR protocol settings
PictBridge Communication
Direct connection settings (greyed out, not able to select)
Please advise.
07-22-2016 01:20 PM
Hi klongbaker,
Please try Standard Setup instead:
5. Select Standard setup and press OK.
6. Select your wireless network from the list that appears and press OK.
7. Enter your wireless network password and press OK.
Your PIXMA MG5720 should now be connected to your wireless network.
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
06-21-2019 09:17 PM
I can go through those steps just fine. My issue is my internet is password protected - but when selecting on the printer it begins to try to connect without a prompt to imput the password. So the result, it tries to connect and then gives me an error message. Not suprising as I was unable to provide the password.
08-25-2019 10:26 AM
Hello, I am having the same problem. I follow the steps to point 7 - select the router name, but the option to enter my wireless password does not come up.
Please help.
08-27-2019 12:41 PM
Hi eileen22,
Who is the manufacturer and what is the model number of your router?
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. For a quicker response, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
08-27-2019 03:44 PM
08-27-2019 04:11 PM
08-27-2019 05:29 PM
Resolved. Thank you.
