PIXMA G3270 connection issue, printer goes offline
VENUS5PSYCHE
I recently bought my printer. I was able to add it as my printer on mac after numerous tries. It shows online but when I try to print something it goes offline. I tried with my phone same thing. It shows connected to wifi on the printer itself. I printed the network configuration page and it seems that there is no issue. Anyone having the same issue? if yes i will just return it and buy a different brand.
4 REPLIES 4
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, we will need to know which version of macOS are you using? Do you connect to your printer using a USB cable or Wi-Fi?  Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
I’m using Sonoma 14.2.1 for my Mac and iOS 17.2 for my iPhone. I was trying to connect via wifi and tried direct connection as well but no luck. I can’t print anything as the printer goes offline after sending a job to print.
I am having trouble printing from my iPhone.  Printer shows online but on my iPhone offline.  Sometimes if I’m lucky after several minutes I can get it to connect.  It always shows no air printer found.
Staceyt43
Having same issue. Has anyone responded?
