PIXMA G3200 - wifi change
Brinkapie
I would like to change the wifi connection on my PIXMA G3200. I have tried a few things in this forum with no luck - maybe I'm missing something. Can someone help with changing from my previous wifi to my recent. OR should I do factory reset? - which I have tried also with no luck
1 REPLY 1
Patrick
Hi Brinkapie,
Please make sure that the network that you are attempting to connect your G3200 to is using a 2.4 Ghz signal and WPA2 security.
If your router has a WPS button, you can use the steps on this page:
What is WPS and how do I use it to set up the G3200 printer on the wireless LAN?
Another way to connect your G3200 is by using Easy Wireless Connect:
How to Start Easy Wireless Connect Setup - G3200
Friends and Family
