‎06-01-2024
02:40 PM
‎06-01-2024
02:42 PM
Hello All!
I need to re-install my Canon PIXMA MX490 Printer, but lost my install CD. Any way I can re-install w/o my install CD? My printer is not recogonizing my desktop computer, nor is it connecting to my WiFi. Everything worked before my new Dell was installed. Then all of a sudden, even though all things were functioning well, the desktop would tell me, or the printer would tell the computer, it was offline. NOTHING had been moved, changed, or touched. Then a smart friend, who said, "I know how to fix this!" (famous last words) and removed all the Printer and parts (fax, etc) from the Settings!!! NOW, of course, I can't get it back into the computer, w/o re-installing it! Is there a free installation download to use, or must I buy another installation cd??
Thanks in advance!
Lisa
‎06-02-2024 08:18 PM
Not sure what 1.03 GPS is.
A dual or triband wireless network broadcasts on 2.4Ghz / 5Ghz and newer equipment supports Wi-Fi 6 and 7.
The printer however will only connect to a 2.4Ghz broadcast.
The link Danny provided above includes downloads for all the software available your printer.
Set up instructions are also available there (images I posted). Before running the set up utility, the printer must be put into set up mode.
‎06-01-2024 02:44 PM
Addendum to above question:
The computer & Printer are about 5 yrs old, and haven't ever given me any problems til this year. I'm also trying to get the Printer to recognize and connect to my new WiFi...and that's not cooperating! I try to print from my computer to printer, when I send the document, the Queue says holds it and I get a msg saying the printer isn't responding.
Thanks for joining the conversation, Lisa! You can download everything you need for your PIXMA MX490 for free on the Canon USA web site. Just go HERE.
Hope this helps!
‎06-01-2024 04:09 PM
Greetings LiseF,
@Danny has provided a link to your printer's support portal.
The printer has a 2.4Ghz radio and requires a 2.4Ghz wireless broadcast that supports WPA2 / AES encryption. Please ensure your network supports these requirements.
The support portal also has instructions for wireless set up.
The printer must be put into Wireless Set Up mode in order to connect or associate with a wireless broadcast. This step is often overlooked.
‎06-02-2024 07:22 PM
My network is 1.03 GPS...is that the network you're talking about?
‎06-02-2024 07:26 PM
Everything was running, Wifi, wireless, printer...then nothing! Msg I kept getting was printer is offline...that's when scanning stopped working and now printing from desktop
‎06-04-2024 01:15 PM
Hi RIck,
I meant to say I have 1.03 Gbps for WiFi speed
‎06-04-2024 03:29 PM
I did just as your instructions stated. It worked! I am online and connected to the WiFi in the house. HOWEVER, when I went to test print something from my desktop to the printer, I got the same ol' message BEFORE a new ISP was installed to the house: "Printer not responding"
Any advice on this?
Thanks in advance. Lisa
‎06-05-2024 12:45 PM
Hi All,
I have a Canon PIXMA MX490 series printer...it stopped working or printing from my desktop. I have gotten a "Printer not responding" msg, for a while. Almost a month ago, I got connected to a new ISP. I had help on this board from shadowsports/aka: Rick, on how to get my stubborn printer to recognize the new isp/WiFi...that worked! So, I am online with WiFi on the printer. I gave it a test print..."printer not responding" . I did a troubleshooter: all systems clear...except one: Problem with Printer: "There might be a problems with Canon Mx490 series Printer. Windows will take additional steps to further troubleshoot." HOW does THAT work?? Does anyone have any advice on how to get my printer to work? There is nothing in the queue...that's been all cleared. My other option is to take it back to Staples! I'd rather fix it at home, if possible.
Thanks in advance,
Lise
