11-25-2024 01:05 PM
we need these drivers but the site seems to be down, Color imageclass mf654cdw.
any help would be greatly appreciated.
11-25-2024 01:40 PM
Hello!
All available software and drivers are on our site at https://canon.us/MF654Cdwsoftware
You may need to verify or select your Operating System & Version from the dropdown menus to see everything.
11-25-2024 01:47 PM
Thanks for the link, but upon selecting the download the page fails to respond error comes up.
11-25-2024 02:32 PM
Sorry, what error?
All you have to do is tap the link: https://canon.us/MF654Cdwsoftware
It will take you where you should be. Select the correct operating system/version (for example Windows 11):
Then, you'll be met with a couple of "RECOMMENDED" options. The easiest way to handle this is to select the "DOWNLOAD" button right next to the "Master Setup." It contains the recommended Canon software and drivers, including the UFR II drivers. You also have the option to select only the MFDrivers suite, which includes the UFR II driver. Here's the screen:
If you'd like someone to help walk you through this process to ensure you have the correct software selected, don't hesitate to call our friendly support team at 800-OK-CANON (800-652-2666), weekdays from 9 a.m. to 6 p.m. (ET).
