07-26-2026
03:19 PM
03:25 PM
James_C
Printer Canon Imageclass MF 249 DW operating system is Windows10 64 bit. two daysI sent a fax to a hospital to receive some documents. The facts the not go to anti-guts effects report immediately. I tried several times but I keep getting the facts reports that he did not go through. So the following day I saw that the processing/data l continue to flash green light. I cried many times to get it fixed that was not successful. Unfortunately I called Canon and he told me that's – no more update on this printer. Right now I cannot fax and I cannot receive fax. When people fax to this printer it is them that it is engage. And on the screen when this light is flashing I see that I get a message that says receiving. I need some help since I cannot get any help from Canon because the state the date no more updates on these facts machine
07-26-2026 06:38 PM
Do you have phone you can check your land line with?
If the busy signal persists after these steps, consider the following:
07-26-2026 03:46 PM
. Printer canon image class mf 249 dw operating system is Windows 10 64 bit. two days ago I sent a fax to a hospital to get some documents. The fax I sent did not go through and I received a fax report that it was not successful. I tried many times to send fax and I got fax reports that they did not go through. The following day I found out that the processing/data on the pretest screen continue flashing green light. I called Canon for technical supports but I was told that there was no more update for this printer. When I disconnect the phone cable, the green flashing light disappears. When is connected the flashing light comes on and on the screen of the printer I see a message saying receiving. I have disable the autodial belt to prevent it from redialing. when this light continues to flash I cannot send or receive fax. and when people send fax it creates that my fax machine is engaged. and need some help
07-26-2026 06:38 PM
07-26-2026 09:12 PM
One additional question. Is the phone line connected to the Fax port analog or VOIP?
07-26-2026 11:04 PM
Good question.
07-27-2026 01:02 AM
I have tried all of your above suggestions, but the green light continue to flash when I reconnected the phone cable. No flashing when the phone is not connected. I will try Factory reset today.
07-27-2026 09:41 AM
Duplicate post
07-27-2026 10:17 AM
Although you've marked this post as solved, you appear to still have an issue.
I suggest you review the user guide below before resetting the device.
Your phone line has to be connected to the lower port on the back of the printer. An analog phone line is recommended. Some VoIP providers support fax functions but you should confirm this If you are using a internet-based connection.
Deciding which fax receive mode to use:
Please confirm the above connection in settings.
