12-26-2025
12:44 PM
12:49 PM
Hello everyone!
Just got a new Canon that I'm very excited about! Unfortunately, it refuses to connect to my network. I will buy a USB cable if I have to but would prefer to just connect it over Wi-fi.
I have tried restarting my printer, the devices I'm trying to connect it to, and my router.
I have seen some people suggest connecting with a guest network, but that isn't something that my router is able to do.
Similarly, when I go into the app on my phone, it works right up until I connect to the canon Wi-fi, when it tells me I am "connected without internet". Unhelpful.
Does anyone have any more things I could try?
Thanks in advance!
#iP8720
12-26-2025 02:54 PM
How is the network configured? The printer requires a 2.4 GHz broadcast that uses WPA2 encryption. Does your network meet these requirements?
12-26-2025 07:30 PM
Oh, I see! My network has a WPA2 encryption but 5GHz broadcast. Is there any way around this or am I out a printer?
Thanks so much for the response!
12-27-2025 09:02 AM - edited 12-27-2025 09:28 AM
While possible, it's rare that a standard router is only a single band like 5G. This type of router is usually relegated to mobile or hotspot types. Netgear, T-Mobile are examples.
If your router only has a 5 GHz broadcast, the printer is not compatible unfortunately.
12-27-2025 05:11 PM
What brand and model is your router? I bet it has two bands but the 2.4ghz most likely needs to be enabled.
12-28-2025 01:11 PM
I found out a way to enable 2.4GHz on both my computer and phone and it STILL says it's "failing to communicate with printer". UGH! Any idea why that would be??
12-28-2025 01:11 PM
I found out a way to enable 2.4ghz on both my computer and phone and it STILL says it's "failing to communicate with printer". UGH! Any idea why that would be??
12-28-2025 01:26 PM
Try to reinstall the Canon software. You can get it from here: https://ij.start.canon/ip8720
It will walk you through the steps. If you get stuck, be sure your printer is registered at https://canon.us/account and give our team a call during normal business hours, at 1-800-OK-CANON (800-652-2666).
01-02-2026 10:25 AM - edited 01-02-2026 10:26 AM
I agree with Stephen's post, it is likely that your Canon software did not complete its installation due to not being able to connect the printer to your wifi.
