Mac OS Sonoma 14.0 / Compatibility with Print Studio Pro and Print & Layout
EduardoAlemao
Enthusiast
New Mac OS today. Any thoughts?
Wonder if Print Studio Pro / Print & Layout plugins will run properly....?
SRbaumbach
Canon just released Print Studio Pro 1.3.8 dated 9/16/23 and it works fine.  Thanks Canon IT for a quick fix as print jobs were piling up.
25 REPLIES 25
Make A Time Machine back up of your current install.  Then you can try or test Sonoma.
Time Machine is free.  If it doesn't work out, you can roll back.
timstorm
My early feedback is “don’t do it”
having issues with print and layout manager as well as accounting manager.  Looks like updates will be needed from canon.
EduardoAlemao
Enthusiast
I dit it!
At first all sort of problems.... Reinstalled all drivers, PSP, PPL, using the last ones I could find.
Now the printers are working. From time to time I got that "not enough memory" message.... Anoying but restarting Ps and Lr do the trick.
I am using PP&L with a Pixma Pro 200
After upgrading to Sonoma 14.0  I get this error when I try to print a second page
CNPPLAPP quite unexpectedly and PP&L quits unexpectedly.  I have to force quit the PP&L print manager and re-start everything.
After a lengthy chat with Canon support this afternoon I have no solution.  They suggested I delete and re-install PP&L.  I would lose all my custom layouts which would be a major loss and there is no reassurance that the re-install would fix the problem.  They also suggested that I export my print jobs to JPG and use Easy Photo Print Editor.  I took a look at this possible solution.  I don't see an export function anywhere in PP&L.  EasyPhoto Print Editor won't do what I am trying to do.
So, right now, I don't have a solution.
I may roll my OS upgrade back so I can get some work done.
SRbaumbach
You would think that Canon would hit the ground running for at least one of these MAC OS upgrades.  I have 4 large format printers, lots of business but a crap program.  Canon get off your keyster and fix this.  Sonoma issue is the memory dialogue after one print.  I have PLENTY of memory.
This is what I don't get.  Wait of the OS upgrade then fix the code.  Apple:  Meet Canon.  Canon: Meet Apple.  Now get together and fix this.
Right, but keep in mind that when you revert to a previous version of the OS, even using Time Machine, it will wipe your drive and reinstall the OS.  Any changes, editions, deletions to document or image files, etc made after the upgrade will be lost.  It has been two weeks since I upgraded so I am preparing to roll back to Ventura but first I am copying all my spreadsheets, images, etc onto a flash drive so I can put them back on later.  I expect that any customizations to the OS, for example screen savers and desktop, will be lost.  There will no doubt be some things that will be missed and I will be correcting and fixing things for weeks . . .
That's right. Memory and some Error when sendig files....
After looking into rolling back to Ventura I have decided not to do it.  Not only would I lose changes to obvious files like spreadsheets and images on my hard drive, but also updates to Adobe Lightroom, one of the messaging apps and data for other apps that I am unable to easily identify.  Software updates will also be lost or scrambled.  Rolling back would cause too much havoc.  I have one big show a year and now I have only 50% of the inventory I need for it.  I have already purchased the paper and ink and packaging and have been confirmed in the show.  Instead of my big money maker for the year, I am going to take a big loss unless Canon gets an upgrade out for PP&L soon.
