MX860 doesn't print within same WiFi Network
ptownsend
I have a FiOS (Actiontec) router (SSID say AB) and a bridge (SSID say AB-5G).  All the devices seamlessly
work with this setup except for my MX860 printer.
The MX860 is configured to be able to print wirelesslessly and I can see the printer from the router and can
ping it.  It has a static IP address assigned to it.
When a print job is submitted from WiFi network AB to the MX860, I get connection error 300 and the job
does not print.  When I switch the WiFi network on my Mac (and other Macs on the network) to AB-5G
the print job resumes and prints.
Security is WPA2 as verified on the router as well as on the MX860 WLAN setting list.
(Somewhere, I heard a Canon rep respond to a post that if this is an urgent request, the consumer
should contact Canon support.  I think you are a decade behind with your support model and don't
really understand where the consumer / retail product model has moved.)
0 REPLIES 0
Holiday
