04-08-2020 03:32 PM
I am having problems with my printer a message continues to appear to say ink cartridges improperly install. I have removed and replace ink cartridges several times still message appear and unable to print.
04-08-2020 03:55 PM
Not saying you necessarily have these issues, but things that can trigger an error message like that are 1. cartridges in incorrect location and 2. incomplete removal of protective film.
04-15-2020 06:12 PM
Hi ADMIN1,
If you are getting an ink tank recognition error, you can try removing the inks from the printer and then turning the printer off and back on. When the printer is back on and the ink carriage has moved to the ink changing position, you can reload the tanks into the printer.
If that does not resolve your issue, I will need some additional information to assist further. If you can reply to this message with the information below.
04-15-2020 09:15 PM
I have tried the solution that you suggest. now it gives a message saying out of ink. thanks for the support.
