07-20-2015 04:57 AM
Recently I was forced to set up a new user on my Mac (OSX Yosemite) and since then the scanner on my MX410 does not work wirelessly. I get the message:
Cannot scan for these reasons:
-Scanner is turned off.
-USB cable is disconnected.
Please check and try again.
Scanner driver will be closed.
2.156.0
If I change users to the older user, it works just fine. Also if I go into System Pref/Printers & Scanners/Scan/Open Scanner it scans fine wirelessly.
Any suggestions or recommendations?
Thanks
07-20-2015 05:37 PM
07-20-2015 05:37 PM
07-21-2015 12:55 AM
Thank you very much @merrymary247. The link you sent was very helpful and sorted me out. It seems in MP Navigator EX the selected scanner was MX410 instead of MX 410 Network. When looking at the Preferences I would see MX410 and think it is the correct one and would not bother to investigate further!
Thanks again.
