MG6620 Printer WiFi Connection
AdeV
I recently got a new internet provider and my printer is not connecting. I tried disabling the wifi, resetting it but I can not get it to bring up the password screen so I can enter it. It's like it's still trying to connect to the old one. Any help is appreciated. I have a MG6620 printer.
Darius
Whiz
Hello AdeV.
In case you have trouble with the interactive guide, the Standard Setup guide may be found at the following link:
https://support.usa.canon.com/kb/index?page=content&id=ART116357
If the Standard Setup fails before you can enter a password, then the router is denying that opportunity.  In that case, use the WPS PIN Code setup method (refer to your router's support for directions on its side of the process).
If you need immediate assistance with this issue, please contact us using the numbers and information at http://Canon.us/ContactLI
3 REPLIES 3
Start here.
http://downloads.canon.com/html/wireless/modules/14alw-ww/14alw-sts-ww-0001-001/14alw-sts-ww-0001-00...
Darius
Whiz
Hello AdeV.
Thank you! The pin code method worked! It took a little time but it worked perfectly! Couldn't be happier!
