MF Scan Utility missing shrink/resize feature
snifferpro
The MF Scan Utility has no ability to shrink or resize.  Been that way since day 1.
 Has no - or box to shrink.  Only thing in top right hand corner is the X to kiil the APP.
Should be able to shrink or resize at will.
Anyone else experience this?
Is the MF Scan Utility the only way to start a scan session?
How do you contact support to suggest a software update to the MF Scan Utility?
Everything else is fine with my MF465DW printer.
Can't believe Canon created a scan utility without the ability to scan or shrink.
Thoughts please.
4 REPLIES 4
Greetings
MF Scan Utility - This is expected, it's not an oversight.
Did you install ScanGear?
This is what you would use to select a custom output size.
snifferpro
Scangear was installed during the entire install process.
However, I have no Icon for SCANGEAR.
I hav e an icon for the MF Scan Utility which when opened,I click on SCAN and then
SCANGEAR opens up.
Seems a little backwards to me.
Also, most screens from apps on windows always have the buttons on the top right side
of the pop up.
You don't have the ScanGear option in the MF Scan Utility?
I have the screen you are showing, but it is not resizeable.
Because of poor vision I have increased the text size on my monitor.  I do have the Scan Gear button
on that screen, but that screen should be made sizeable and shrinkable.
