10-24-2023
08:34 AM
10:29 AM
Is there a software driver for the mf 4880dw printer for Windows 11?
Having trouble locating it. Or should I just throw the printer away?
thank you!
10-24-2023 09:39 AM
@Russ2,
Please at least try the Windows 10 drivers with W11. There is a good chance they will work.
10-24-2023 08:44 AM
Hi Russ2
Available downloadable drivers for the imageCLASS MF4880dw can be found at https://canon.us/3SbvLIg. Once you go to the link, click the "Software & Drivers" tab to locate the downloads.
We hope this helps.
10-24-2023 09:05 AM
I looked there. The only drivers there relate to scanning and toolbox types.
My windows 11 new computer also said there is no driver available.
So honestly I think it's toast.
10-24-2023 09:27 AM
This unit was retired right around the time Windows 11 came out, so it does look like no software or drivers for WIndows 11 were developed. We recommend taking advantage of the Canon Upgrade Program so you can get into a modern printer that is compatible with your modern OS at a discount. Get in touch with a specialist at 866-443-8002, Monday through Friday from 9am to 9pm (ET).
10-24-2023 09:39 AM
@Russ2,
10-26-2023 09:47 AM
Seems to be printing ok with the Windows 10 driver.
Thank you!
10-26-2023 10:06 AM
Glad it helped.
