08-19-2020
06:38 PM
02:22 PM
I have four printers listed in Windows for my Maxify MB2320.
First, is there duplication here? When I right-click and select printer properties on #1 it displays a menu of three printers (MB2300 series, the fax, and the XPS). Each uses a USB port.
The printer properties for #2, #3, and #4 show a network port connection. I haven't used an ethernet connection in a while though. Or is this appearing from the network?
Second, when I print, which is best to use? XPS or the regular driver?
Thanks.
08-27-2020 04:43 PM
Hi Mike20878.
If the printer is detected on a particular connection, most computers are set up in advance to automatically register them as they're detected. Additionally, Windows will treat the USB connection as a completely separate device from the same device on WiFi. To minimize confusion on the USB connection, I recommend removing all of the MB2300 series entries, then removing the USB cord, wait ~ 12 seconds, then reconnect it. The printer should be re-registered automatically with the Canon-produced drivers.
The XPS drivers are extra drives for specialized printing applications. You will only need them if you have software that specifically asks for that type of driver.
08-27-2020 04:43 PM
Hi Mike20878.
