12-13-2022
12:28 PM
12:36 PM
I'm using a Canon MB2700 Series, and i want to put a destionation folder for scan, but isn't working!! look at print and help me. translating is: Folder connection failed. Check the settings.
03-27-2024 06:02 PM
I have this same problem. The windows machine can easily map the network drive/location, but the Canon software can't. That is kinda silly. Perhaps because it has spaces? My mapping is like this:
\\192.168.15.142\GoFlex Home Backup\ColorCanon
I actually use the browse button and it finds it easily. I KNOW its not a typo, its exactly the same for the mapping to S:/ that I use. The user name and password are the same on the destination machine as they are on the local machine. As I said the windows mapping has no problem, only the silly quick utility tool seems to have an issue with it. Is there some OTHER way I can put this in as my destination?
Full disclosure - small shop, we use only linux. The destination is a network drive using type 1 mounts, which I enabled on the window 10 machine that I had to BORROW to set this up. Every single other thing about the printer was flawless, it works very well, I just really need to scan and have it put the pdf files to a consistent network location. The laser brother printers I have here have no trouble and set up easily, directly from the printer itself. Very annoying.
