LBP6000 Series suggestion for turning on double-sided printing via driver
mehdigh
Greetings and respects,
I used to have a 1020 hp printer that had a very practical capability, and when I wanted to print 20 pages on the back and front, for example, it had an option for two-sided printing, and there was no need for me to rearrange the pages manually when it printed one side.
First to the end, but this feature is not in the Canon printer, unfortunately.
I will put the picture of the available option so that you can understand it better.
Moderator
Moderator
Thanks for joining the conversation, mehdigh!
So that the Community can help you better, we need to know exactly which Canon printer model you're using.  The model number should appear on the front of the print beneath the Canon logo. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
5 REPLIES 5
Moderator
Moderator
If you have a LBP6030,,  it does not support duplex printing.  This is listed in the specs
Duplex: No
Canon Support for imageCLASS LBP6030w | Canon U.S.A., Inc.
If you need duplex printing, I'd purchase a duplex capable printer.  The amount of time you would have to spend selecting the odd number pages and reloading paper is not practical.
hi , the model is 6018L
Of course, I bought the HP 1020 printer that I used to have 15 years ago, and this feature was very good, I expected it to have a Canon printer as well.
Thank you for your guidance.
Greetings ,
The 6018L doesn't support automatic duplex printing either.  Like the 6030 above, you would need to print and refeed the printed pages to print on the other side.  This is a manual process.
